Heavy White Smoke????
Old 07-17-2009, 06:48 AM
Redliner's Avatar
Just got done with a Helix 2 cam install. Went to start truck and broke in cam no problems. If the truck is cold, when you start it it will BILLOW out heavy white smoke like its getting too much fuel. Is this from the cam cause that is the only thing we changed????? Truck is an 01 and still running the VP.
Old 07-19-2009, 03:30 AM
jcarrillo's Avatar
Does it miss? Check for a tight valve. The only other thing I can think off is your pump gear got retarded a tooth when you installed the cam.
Old 07-19-2009, 07:44 AM
olddodgetruck's Avatar
definatly reset valve lash if you havent already
Old 07-20-2009, 06:09 AM
Redliner's Avatar
did that think a copper washer is not sealing correctly got new ones comin
Old 07-20-2009, 06:30 AM
j-fox's Avatar
White smoke is usually a timing issue.
Old 07-20-2009, 09:16 AM
Redliner's Avatar
How can it be out of time? There was a keyway on the cam. It is very rich fuel smell when it starts so im thinking its a copper washer bleeding down.
Old 07-29-2009, 08:29 AM
Redliner's Avatar
Well copper washers didnt fix it. Can a VP go bad by pulling it of and puttin it back on???? Or was it on its way out and just now did????
Old 07-29-2009, 08:59 AM
Cowboy_Customs's Avatar
I am not familliar with the 24 valves, but the heavy white smoke indicates timing. How does it run? Have you tried to drive it? I understand the cam is keyed, but it very well have been put in off, and the valve adjustment to an off cam placement will only compound things. Better check your cam timing.
Old 07-29-2009, 11:57 AM
Redliner's Avatar
Runs great Pulls hard up to 3800rpm. Just when starting it looks like a decompressed motor trying to start.
Old 07-29-2009, 08:26 PM
Number47's Avatar
grey smoke is a fuel timing issue. white smoke is coolant
Old 07-29-2009, 08:31 PM
bnold's Avatar
gear sounds off a tooth...
Old 07-29-2009, 09:25 PM
HOHN's Avatar
It's hard to tell on a cold engine. When my M4s haze in a bitter cold start, it sure looks white to me.
The timing could definitely be off. Are you certain that the cam isn't off a tooth or two? If you have radically retarded cam timing, you'll be closing the intake valves way late, which means you'll have much lower cylinder pressure and less air at the time of injection, at least at low RPM.
If this is severe enough, this would cause a white smoke because it won't even get hot enough to turn the fuel to soot.
Does it go away when the engine is warm, or greatly reduce?
If so, I highly suspect your cam is retarded by a tooth or more. Another clue to a retarded cam is if it pulls to higher RPM than it really should or feels soft on the bottom.
Old 07-30-2009, 05:51 AM
XLR8R's Avatar
Keyway doesn't matter - still have to align the "O"s & "OO"s... 36/72 crank/cam teeth I bet your timing is off 10 degrees, and make sure the IP is phased correctly.
Old 07-30-2009, 06:25 AM
Redliner's Avatar
Ok so it looks like were pullin the cover off again..... One of my x-employees put the cam in the block and put the pump on. I wasnt there.
Old 07-30-2009, 06:36 AM
Redliner's Avatar
Hohn, the smoke is less when its warm. After a sled pull and u shut it down after cool down. It sat for a about 10 min and was REALLY hard to start and heavy white smoke.
RJOS
16
09-03-2007 09:19 PM
BuildingBoost
03-25-2007 07:46 PM
BlackSheep5
11-27-2006 07:52 PM
04ctd
26
09-25-2006 09:47 PM
dhe9
11-14-2003 07:31 AM
Quick Reply: Heavy White Smoke????
