heater motor
Old 12-22-2008, 11:15 PM
johnh's Avatar
heater motor
here's something i found out ...... if your heater motor resistor is burning out. replace your heater motor..... the bearings get dry and cause more heat in the resistor than it can handle.
i put 2 resistors in mine before i decided something was causing the failure
i removed the blower motor and it was real hard to turn..
funny thing ,it did not make any noise.........
Old 12-23-2008, 07:25 AM
Pickin on the wrong admin...
Diesel Dave2's Avatar
Good advice John...I'm going to pick up a fan just in case,when I replace my heater core.Where did you buy the fan motor from??Maybe would NAPA have them.
Old 12-23-2008, 08:27 AM
johnh's Avatar
napa's units are generic , no connector.
here's the one i bought. http://cgi.ebay.com:80/ebaymotors/ws...m=120306331347
Old 12-23-2008, 09:06 AM
GAmes's Avatar
I got mine at a pick & pull. $10 for fan and resistor. 1500s thru 3500s, 94 to 02 are the same, so they are easy to find.
Old 06-25-2013, 03:15 PM
diklohill's Avatar
on high speed my fan makes a loud flutter noise but is fairly quiet on lower speeds would this be from bad bearings
Old 06-26-2013, 12:19 AM
joem's Avatar
It would, mine also screams at me until its been on for a few minutes. There has to be a grease zerk or oil hole somewhere in there....right??
Old 06-26-2013, 03:13 AM
diklohill's Avatar
maybe , maybe not I will find out , I am going to pull mine off and check it out,
Old 07-05-2013, 11:50 AM
Tallguy67's Avatar
I replaced my HVAC motor just over a year ago. A bunch of folks on here recommended I go with a Bosch from the dealer. The price difference between dealer and aftermarket stores was very small. I think I paid $170 and the aftermarket was $150.
There were no grease zerks on it or anything, I believe it has nylon bushings not bearings.
Old 07-05-2013, 12:05 PM
24V83's Avatar
Does anyone have a part number for the resistor?
Old 07-05-2013, 07:13 PM
blackimpala's Avatar
I know that a bad motor can take out the resister but not always. Replaced my resister about two years ago still going strong.
Floyd
Rednecktastic
12-18-2009 08:58 PM
ryan10
08-10-2007 09:38 PM
Common
05-09-2007 12:11 AM
coupdetat
02-17-2007 12:52 AM
Quick Reply: heater motor
