Heater grid , what triggers soleniod ?
Old 12-08-2011, 05:27 PM
SKATERHAULER's Avatar
Been trouble shooting grid heater . Grid Ok , solenoid Ok as well as all connections . When I ground small lug on Sol grid heats up . Simply put where does the Solenoid get signal from ? Is there a fuse somewhere ?
Old 12-09-2011, 08:08 AM
patdaly's Avatar
Signal from PCM, more correctly, PCM drags the coil to ground.
Not sure if the 95 follows the 97, but on 97's, PCM connector C1, pins A9 is relay # 2 control, and C1, pin A7 is relay #1 control.
Check you air intake temperature sensor, that is what I believe tells it it is cold enough to fire.
Old 12-09-2011, 10:31 AM
infidel's Avatar
Everything you need to know about the grids> http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
chadwick
05-18-2006 06:31 AM
tyssniffen
03-26-2006 07:15 PM
93' Shorty
10-28-2004 01:48 AM
Got Smoke?
05-27-2003 09:13 AM
Quick Reply: Heater grid , what triggers soleniod ?
