View Full Version : Heater control valve
Lightweight
11-22-2009, 11:43 AM
Hi Folks,
I want to put a ball valve in the heater hose, for improved a/c???, next summer.
The inlet to the heater core or pressure side is the valve?[dummy]
GW
ppiggppenn
11-22-2009, 01:07 PM
I don't think it matters too much which hose you use as long as you stop coolant flow to the exchanger, just grab the one more convenient for controlling the shut-off, ... :cool:
Jim Lane
11-22-2009, 02:18 PM
This is where the water valve is located from the factory on my 1991 D-350, it is on the left.
http://i16.photobucket.com/albums/b38/LaneJ/IMG_5113.jpg
This will make your air a lot cooler inside the cab, now you will not be having to cool down 140* incoming air with your evaporator.
From my post,
http://www.dieseltruckresource.com/dev/showthread.php?t=209772
Jim
Lightweight
11-22-2009, 04:10 PM
Thanks Guys,
That is what I thought.
Mr. Lane, my 92 is set up the same as your's.
WEll it will be tomorrow, anyway.[coffee]
GW
