heated seat flashing
Old 02-21-2009, 02:04 PM
arabian knight's Avatar
just curious if anyone knows why my driver seat heater isn't working. When i push high button, the low light comes on and starts to flash. can anyone just give me an idea to fix it. Or if it's fixable.
Old 02-21-2009, 11:07 PM
WestTN's Avatar
when one is flashing it means an open circuit. When the other flashes it means a short. I just don't remember which is which. An open circuit is the most common.
Old 02-22-2009, 05:54 PM
is it an easy thing to fix,when you say open circuit do you mean it's shorting out somewhere. i live up in canada, and it's **** cold to get in a leather seated truck, when it's -30
Old 02-22-2009, 09:32 PM
WestTN's Avatar
Okay, here are the facts.
Both lights flashing on either switch means the that element is shorted.
If element open, the high light only is blinking
If sensor out of range, the low light only is blinking.
This is from 2001 factory service manual.
BigSexy01 (06-16-2020)
Old 02-23-2009, 09:34 AM
your the best buddy, i have the low light flashing, what does out of range mean? That it's unplugged.
Old 02-23-2009, 07:02 PM
WestTN's Avatar
That or a wire is broken off the sensor.
Old 03-01-2009, 02:04 PM
the sensor would be in the seat, right
Old 03-01-2009, 02:08 PM
WestTN's Avatar
Yes, the drawing in the service manual shows it pretty close to where the wiring enters the seat.
Old 03-01-2009, 02:56 PM
Top's Younger Twin
Scotty's Avatar
My 01 did that and it was a broken wire right about where westTN described.
I peeled off the leather cover to find that the wire to the heater in the foam was broke too. Repaired and it worked perfect. I think that the wires into the foam of the seat do not have a lot of give and eventually the wire snaps.
Scotty
Old 03-01-2009, 04:33 PM
you guys are great thanks a lot, I just figured out the problem, I'm a person who's always adjusting the seats height. So that's my problem. I'm going to try and fix it and Ill message you boys if it works.
04ctd
04-17-2007 09:01 PM
sandpuller2004
03-08-2007 11:03 AM
ta3834bbl
12-30-2004 05:29 PM
Quick Reply: heated seat flashing
