Headlights Not Working, Help!!!!!
All Other Lights Are Working, But Headlights Do Not Come On. Switch Feels Like Its Working, Fuses In Cab Are Fine, Just Can't Figure Out Problem. Any Info. Greatly Appreciated.
Flip the bright/dim lever and let "snap" back. See if that helps. Sometimes my bright/dim switch hangs between positions and I have to flip the lever a time or two.
are both beams on both lamps inop or just low. check fuses-under hood i think. couple months ago my 98 started to flash lamps off/on when switch was on. the headlamp switch has a built in circuit breaker if they dont come on at all this breaker could be bad i think mine was getting weak. also when you at the switch check for melted wiring/connector.
Also fill out your sig, so the really smart guys on here can get you up and running faster.
I Can See The Light!!!
I Finally Had Time To Check Out My Truck Today. When I Took My Dashboard Apart, The Headlights Magically Started Working. I Guess It Wasn't Making Contact As It Should Have Been. I'll Have To Bring Back The New I Had Purchased. I Was Expecting The Worst. Anyway, I Appreciate All The Feedback From Everyone. If Anything Changes I'll Let Ya'll Know. Thanks Again.
Sleigher
05-04-2017 02:12 PM
FakeBakn3
07-14-2015 06:08 PM
Michigan Ram
08-24-2011 11:25 PM
