Headlights Low and High beams - Poor
Old 01-03-2005, 07:20 AM
FROSTY1's Avatar
I feel the headlights design on the 03 I traded and the 05 I have now isn't that great. While the lowbeams seem ok ( have to keep that outer lens real clean at all times) I kinda hate the high beams. They just seem soft and weak. Anyone agree, and if so, any bulb change out That may help out?
Old 01-03-2005, 08:19 AM
Top's Younger Twin
Scotty's Avatar
I agree, the high beams seem weak and appear to only light up the ditches.
Not sure about a bulb though...would like to address that. My lights need to be adjusted too. After adding the T rex/Kore suspension and raising the front 2.5" it made the lighting worse...especially when loaded. If it wasn't so cold I would adjust them myself.
Old 01-03-2005, 08:50 AM
GotBoost?'s Avatar
sylvania silverstars will help alot!
Old 01-03-2005, 09:19 AM
WhiteSport600's Avatar
Get a 5" kit and run the factory fog lights! You'll never need the brights again!!!lol
Old 01-03-2005, 10:52 AM
Top's Younger Twin
Scotty's Avatar
I'm running two sets of PIAA's and a pair of Lightforce up front too.
The Lightforce are just a bit too bright.
One set of PIAA's are fog and the other are driving.
The driving lights are nice...the fogs..so so.
I also have different lens covers for the lightforce.
I will look into the silverstars and adjust the factory lights.
Old 01-03-2005, 12:03 PM
Cold Diesel's Avatar
I am using the PIAA 4000K bulbs and they are a real improvement over stock. Expensive though, about $75 for a pair.
Old 01-03-2005, 02:17 PM
Bubba_CTD's Avatar
Location: From Texas; Staioned in WA; Transplanted to AZ
Cool
I have the PIAA Extreme whites in the headlight and foglights and a set of PIAA 510's (fog) on the bull bar. I'm looking at getting a light bar on which I'll mount 4 KC 150W Daylighters to light the road up. I miss being able to light up the road like I've been able to...
Old 01-03-2005, 05:41 PM
Nvisable's Avatar
My experience with silverstars didn't leave me with that Wow! what a difference feeling. I think they only add 3 - 5% more light. Things got a little better with my T-rex leveling kit. I don't use the high beams. They are useless to me.
Old 01-03-2005, 07:21 PM
mikmaze's Avatar
the siverstar helped but only on lowbeam w fogs on as I replaced them as well, only other option is a bite box ... let em all throw some down the road!
Old 01-03-2005, 11:04 PM
Patriot_RAM's Avatar
My lighting stunk until I added the brite box with fog light control. It lights up the high beams, low beams, and fogs when the high is engaged. Made a world of difference!!!
Now the sad part -- Today I removed my fog lights to install my road armor bumpers. I guess it's time for some PIAA lights to run through the brite box. After that project, my high beam switch will engage the high and low filaments as well as a pair of PIAA fogs and a pair of PIAA driving lights.
Old 01-04-2005, 02:02 AM
DSLRammin's Avatar
Tell me more about this brite box. Thats exactly what I'm after. I had started a thread back in Oct about how my headlights suck. By the amount of replies, ALOT of us agree they stink.
Old 01-04-2005, 11:17 AM
GoCarGo's Avatar
Thumbs up
www.bakerautoaccessories.com/BB.main.page.html
I just installed this new britebox with fog control and performed the foglite "fogzilla" modification. I am now VERY impressed with the amount of light The new fog control forces the fogs on in high beam mode (even if fog switch is off). Furthermore, the fogzilla modification substitutes the OEM foglite bulb with a highbeam bulb which nearly doubles the illumination from the foglights alone. Bottom line is with the britebox and fogzilla modifications, there is nearly 3 times the ammount of light comming from your OEM fixtures in highbeam mode ... I highly recommend!!
Old 01-04-2005, 01:04 PM
FROSTY1's Avatar
Great info. Thanks.
Old 01-05-2005, 09:19 AM
phloop's Avatar
Does any one have any ideas on increasing the light out put on just the low beam/fogs? I have had the silverstars installed since the truck was new, it just seems that these stock lights do not project out very well. I rarely use my high beams so the britebox would be a waste of money for me and I'll be converting my fogs over to the high beam bulbs soon. Has any one installed a painless wiring light kit yet, the kind that draws power straight from the battery instead of through the light switch?
Old 01-05-2005, 09:31 AM
I aimed both my lights and my fogs up a little. It helped out quite a bit and I've only been flashed by other drivers two times in the past several months. Much less than my Chevy. People flashed me in it all the time and they were aimed to spec.
Quick Reply: Headlights Low and High beams - Poor
