Headlight problems..help
Old Sep 22, 2008 | 10:39 PM
Buz's Avatar
Buz
When is switch from hi beam to low, sometimes the low beam is out. Flick it a few times and low beams come back on. Is this a bad relay or something. Anyone know how to fix it?
Thanks..
Old Sep 25, 2008 | 07:17 AM
Buz's Avatar
Buz
No ideas? I'm sure someone has had this before?
Old Sep 25, 2008 | 10:37 AM
CarlJensen's Avatar
Multi function switch on steering post. Have read that some just sprayed it with electronics cleaner and worked it to get crud out of contacts.
Old Sep 26, 2008 | 06:48 AM
Buz's Avatar
Buz
Thanks, I'll try it.
Old Sep 29, 2008 | 07:29 AM
VADSLRAM's Avatar
I agree with the stalk switch. If it works sometimes but not always you should always suspect the part that gets the most abuse first. The switch on the column gets moved the most and isn't sealed so dust and grit can get into it.
mtdoragary
Nov 7, 2013 08:31 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
Ian
Feb 11, 2006 08:32 PM
jlipskoc
Oct 24, 2005 01:16 PM
luckydiamondran
Mar 8, 2005 02:17 PM
