Headlight harness
Headlight harness
So is this they key to brighter headlights on our trucks?
http://www.lmctruck.com/icatalog/de/full.aspx?Page=46
I've been thinking about getting this part but not sure if its worth the money. Anyone else install one of these?
I need to get that kit, will make a little brighter but will best of all save your head light switch from failure ED
you can buy a kit from here: http://www.danielsternlighting.com/p.../products.html (# RIK-RAM)
or you can buy a well built harness from here: http://suvlights.com/product_info.php?products_id=112
i had the LMC harness at one time - and it worked well for the time i had it, but i could tell it was built poorly the minute it arrived. i have since done a sport light conversion and built my own harness properly with good compnents.
no. it's a tight fit, but with enough trial and error you will get them off. a smaller set of hands would be great . . . i also used a mini slot screwdriver to release the tabs and then pushed forward slightly instead of doing all the work with your fingers.
mtdoragary
11-07-2013 08:31 AM
evan3000
01-06-2009 12:32 PM
hopak
04-03-2007 12:08 PM
jlipskoc
10-24-2005 01:16 PM
