Headlight Adjustment
Old 10-04-2006, 04:59 AM
RobbieS's Avatar
Question Headlight Adjustment
Hello everyone, I am new here. I just bought a new 2006 silver Quad Cab CTD 2500HD 4WD. I love the truck. I just put spacers on the front coils to level the front end out, and put 315 BFG's on it. After doing this, while driving at night, I get flashed bright lights a lot. I have found one adjusting screw on the side (inside) of the each headlight. I was assuming since it was on the side it was for left/right adjustment. I can't seem to find another adjustment for up/down. Has anyone adjusted their headlights on this model before? I called the dealer. They said they thought that one adjustment was for up/down, but didn't sound very sure. Any help would be appreciated.
Old 10-04-2006, 07:01 AM
MikeyB's Avatar
The adjustment screw next to the grill is the up and down.
MikeyB
Old 10-04-2006, 08:52 AM
RobbieS's Avatar
Thanks for the info. So is there no adjustment for left/right?
Old 10-04-2006, 09:02 AM
MikeyB's Avatar
I know the earlier 3rd gen trucks had a left/right adjustment screw located between the headlight assembly and the bumper, but not sure on the '06s.
MikeyB
Old 10-04-2006, 12:26 PM
schorb's Avatar
I have an early 3rd gen and it has both adjustment screws, or so i thought. I've tried both screws by turning them either way 10 full turns and the headlights didn't move. How many twists does it take to move a light??
Old 10-04-2006, 01:56 PM
MikeyB's Avatar
Both of my adjustment screws work fine. Are you using a T20 torx for the adjustment?
MikeyB
Old 10-04-2006, 01:58 PM
schorb's Avatar
uhhh.....i'll recheck tonight. i thought i was.
Old 10-04-2006, 03:03 PM
ptgarcia's Avatar
Which way do I turn the screw to aim the lights lower?
Old 10-04-2006, 05:04 PM
MikeyB's Avatar
If it's the same as the earlier 3rd gens then counter clockwise will raise the beam and clockwise will lower.
MikeyB
Old 10-04-2006, 09:08 PM
RamWheelsBy4's Avatar
My 04 has only the up/down adjustment screw and I had the same issue when I put the 315s and leveling kit on. I just lined it up in front of the garage and guessed at how much to lower each one. Must have been pretty close not a bright flash since.
mtdoragary
11-07-2013 08:31 AM
jlipskoc
10-24-2005 01:16 PM
mazeeff
08-12-2004 06:40 AM
BigBlackDodge
02-28-2004 10:41 PM
Quick Reply: Headlight Adjustment
