head studs
head studs
when some one tells u to get head studs, what dose that mean, get more, bigger, or what.. i know this is probley a dumb question but ill never know if i dont ask..thanks
fill in ur sig. then we can tell u if u need studs or not. In my opinion, if you dont know what they are and you also have the stock turbo with the silencer ring...u dont need studs
The head is held on from the factory by bolts that thread into the block through the top of the head. Head studs replace the bolts. They are threaded on both ends and thread into the block and the then a nut is applied to the top threads to hold the head in place. This gives better clamping force and they are made of stronger material as well. The purpose is to eliminate the factory bolts from stretching under high cylinder pressure causing the head gasket to blow.
12valvetom
11-27-2009 11:37 PM
dieselboy59
01-30-2009 03:57 PM
smokewagon
08-08-2008 09:54 PM
MikeThomas
05-11-2008 11:39 AM
jmccart
21
05-14-2007 11:47 AM
