head stud torque sequence
does anyone know where i can get the proper torque sequence for installing head studs? When you guys are torquing the studs down to 130 are you using the arp lube or not?
i am planning on doing it one at a time, the head is staying on. the reason i ask is because the instructions say to use lube and torque to 95 or 125 if you use oil only. So wouldn't 130 with lube be way overtorqued?
i did one stud at a time and torqued them to 130 right then and there and moved to the next one.
oaborbag
03-30-2009 07:17 PM
fordsux8269
01-02-2006 01:25 PM
