head removeal and stud install
hey all here soon i will be installing a new stock hg with 12mm studs i was hopeing someone could kinda give me the basic steps in removeing the head and is there any speical tools needed for this job and with the stock hg how much boost will it hol up to???thinks mike..
Mike,
A few simple suggestions. First, located the temp sending unit. The 12 valve is kinda hidden and has a tendancy to hang up because the wiring harness is still attached. You will need to remove the injectors since they protrude below the surface of the head. This will protect the tips from damage.
You will either need a cherry picker or an extra set of hands to get the head safely out of the truck. It is rather heavy.
Other than that, it should be straight forward.
Ronnie
Ronnie
This is not really necessary (at least on mine it wasn't). There are two rubber plugs underneath the wiper cowl that can be removed. This will allow you to get 3 out of 4 of the stated rods out. The last will almost come out. You need to take a pliers and tweak the sheet metal up inside the wiper cowl to gain a hair more clearance and the final rod should come out.
Also for more good info/advice on the whole headgasket ordeal there is a current thread going with alot of good stuff in it.
https://www.dieseltruckresource.com/...d.php?t=194087
lostcreek21
03-01-2010 06:13 PM
willy312221
06-22-2008 07:30 PM
hic316
38
01-12-2008 10:03 PM
