Head Gasket Problems
Old 01-13-2004, 11:06 AM
Beerrunz's Avatar
Question Head Gasket Problems
Have questions reqarding replacing head gasket on a '97 2500 with a 5.9. Two thicknesses of gasket are offered? Which one? Also does anyone out there have the torque specs for this job?
Old 01-13-2004, 04:29 PM
SmokinDodge12V's Avatar
Get the thicker gasket it lowers the compresion a little but not enough to tell. Tourqe # are Step 1 all bolts to 66 ft lbs, step 2 long bolts 89 ft lbs, step 3 all bolts turn an additional 90- degrees, per Haynes Manual.
Old 01-20-2004, 05:42 AM
Beerrunz's Avatar
should I replace head bolts or not?
Old 01-20-2004, 06:23 PM
It would be a good idea to get new ones or at least check the old ones to make sure they havent stretched.
Old 01-21-2004, 06:14 AM
turbo thom's Avatar
Always replace the head bolts. Also when you torque the head start in the center and work out. Front to back.Center front, center back.
There is a procedure to use.
..PT..
Old 01-22-2004, 07:19 PM
Beerrunz's Avatar
ok thanks for the info
ted_pulliam
07-16-2009 11:33 AM
wildchild97
09-25-2007 02:44 PM
blueberry
02-07-2007 05:34 PM
Conn
12-29-2006 06:30 AM
MADSEN
10-07-2004 09:43 PM
Quick Reply: Head Gasket Problems
