head gasket again
head gasket again
i replaced my head gasket 9 months ago and put arp head studs in when i did it. i oil out between the head and the block right in front above the fan pedastel. i think itscoming out the back too but cant see. what would cause this? the most booost it ever sees is 45psi. i was hoping the head studs would hold longer than that.
i have a buddy with a 95, we replaced the head gasket 3 times,less than a year, once after ARPs installed.finally had to have the head milled flat & o ringed.more than a year no problems,money well spent.may be your next(best)step,no more issues or head aches.
Head may not be flat. Did it blow in the same place?
Block not clean/ not flat in said location.
Improperly torqued.
Bad gasket.
In that order.
Improperly torqued.
Bad gasket.
In that order.
0-ringing the head will usually be around $375, plus the cost of milling it flat in the first place.
Usually, with a full machining package and a good valve job the tab will be around $2,300-$2,500. It is money well spent.
redneck, I had the head off on my truck this spring because of a coolant leak on the right side near the front.
The shop sent the head to Northside Engine Rebuilders in Saskatoon.
The head needed to be squared. They did a completed rebuild of the head for $2600 before tax. We priced out reman heads from Cummins and other reputable shops and they were right inline.
I didn't really want to see this bill but with the 480,000 km and many hours of idle time I should not complain.
Stan
Stan
ted_pulliam
07-16-2009 11:33 AM
Need95-00CTD
44
12-21-2007 11:34 AM
West Coast
11-26-2007 09:17 PM
wildchild97
09-25-2007 02:44 PM
