>>> HAYNES or CHILTONS <<<
I am not so much interested in Cummins engine information as I am such things as electrical and chassis information.
With that in mind, which is the better book, Haynes or Chiltons ??
Thanks.
Thanks.
Why not get an FSM? The Haynes and chilton are always lacking...Mark
cds are tough to flip back and forth, from repair info, to schematics, the books are the way to go, ive got haynes manuals that are not schematic accurate, for the diesel, try faxon automotive literature, riverside ca. new manual set for your year, around 80. - 100. well worth it.
I think the factory manuals are the best. They can be purchased fairly cheap now a days. They are model year specific and even gives Miller part #'s for specific tools needed if any.
There are to many mistakes in both companies manuals.
The dealers shop manual is the only way to go. After all these years and manuals I have had for the vehicles I've owned, I'm saving money by using only the shop manuals. When your spending your hard earned money on your personal equipment, you want it right. Not hoping the info is correct, or finding the truth out and buying more parts, making adjustments or flat out cussing about the wrong info.
It's 'YOUR' vehicle, 'your' safety depends on it, get yourself the best.
89 to 90.5 are pretty much identical. I would think that the trucks differences in all the years are minimal, but I do not know when the different ATs were used. You could get 1 early manual and 1 later cd, just an idea...Mark
I believe that is because the Getrag was considered by many to not be rebuildable. I found out otherwise by buying the Motor's Domestic Trans manual when I toasted mine due to that namby-pamby pilot bushing disintegrating and allowing the input shaft to tear itself, its bearing and the countergear to shreds.
