Having a heater problem
Old 12-17-2006, 06:21 AM
Dieseldirt's Avatar
Heater has hot air when the blower fan is off and im cruisin but seems to blow cold air when i turn the fan on. Any ideas? I did just get back from a road trip and it was cold, the truck was parked for maby four days in an area notorious for packrats, would a rat nest block the heatercore and cause cold air to be blown in? Anyways, any suggestions would be appreciated before i start diggin in to it.
Old 12-17-2006, 09:44 AM
That's a good possibility. Also check for low coolant or a defective heater shut off valve.
Old 12-18-2006, 12:26 AM
Diesel Junkie's Avatar
My heater problem ended up being the thermostat.... the engine temp gauge didnt look too cold... about 25% of the total range.... but the heater didnt work worth a squat... i finally figured out that the thermostat had stuck open. The new thermostat rose the gauge to >50 or60% of the gauge range, and the heater worked great.
i had the same problem... heater was warm when there was little or no air moving accross it,, but got colder when the air flow rate was turned up.
Old 12-18-2006, 01:36 AM
Dieseldirt's Avatar
Before my trip i flushed the cooling system and put in a new thermostat, everything seemed to be working great. The temp gauge moves around a lot but i hear thats normal operation for these rigs.
Old 12-18-2006, 05:45 AM
Nathan's Avatar
A year ago I had something similar happen to me, drove for 8 hours with no heat, it got a bit chilly, but it ended up being that the heater core was just plugged, works great now.
COUNTRYBOY
04-25-2009 08:12 PM
bluepuller
04-14-2008 10:15 PM
onetwopunch
06-09-2007 10:49 AM
Capp35
09-29-2005 12:35 PM
greenworks
20
03-29-2005 05:40 PM
Quick Reply: Having a heater problem
