Have to do my clutch 6spd 02
Old 10-08-2005, 09:30 AM
mslipac's Avatar
Truck has been developing hard shifting issues and very hard to get in gear from dead stop...I am thinking clutch!
What clutch would be best bet for me..it's a working truck pulling a 40' trailer 18lbs at a time
Old 10-08-2005, 10:05 AM
spitfire9137's Avatar
Im thinking throwout bearing not clutch
Old 10-08-2005, 03:45 PM
PourinDiesel's Avatar
More like fluid and master/slave cylinder.
Old 10-09-2005, 10:31 AM
mslipac's Avatar
I replaced the whole hyd clutch release system with new oem parts and still the same deal
Old 10-09-2005, 11:06 AM
BigBlue's Avatar
Throwout bearing then.
Old 10-09-2005, 11:38 AM
Could be clutch material build up or syncro's going out.
You might try a fluid change.
Old 10-10-2005, 10:52 AM
getblown5.9's Avatar
when swapping fluid ina manual tranny...how do you know when it is full? where do you check.
word is the NV5600 holds roughly 4-5 quarts...and i have the fast coolers which hold an extra quart each so i have 7 quarts of royal purple synchromax ready to go in...but i dont wanna over/underfill it.
Old 10-10-2005, 10:54 AM
drew03's Avatar
if your going to take it down to do a throwout bearing why not slap a new clutch in there as well?
Old 10-10-2005, 11:30 AM
RustyJC's Avatar
I'm thinking pilot bearing - I would certainly change it if you have the transmission out.
Rusty
Old 10-10-2005, 03:12 PM
dodgediesel4x4's Avatar
After draining out as much fluid as possible (w/ pto cover off, get a rag and sob up as much as possible), fill it to the top of the fill hole. I wouldn't worry about getting "too much" in there. I think the only way to do that would be to overfill it from the top of the tranny via the shifter. You can fill it with a pump, or someone here used a 6ft hose and did it from up top.
Old 10-11-2005, 02:04 AM
95ram's Avatar
My vote goes to either throwout bearing or pilot bearing. Mine is worse now after changing the clutch.
westport
11-24-2005 01:43 AM
norsk
07-19-2005 08:26 PM
bennydodge
01-20-2004 10:47 PM
B-Peterson
12-03-2002 09:17 PM
xzlram
11-10-2002 08:28 PM
Quick Reply: Have to do my clutch 6spd 02
