have a code need help
Old Nov 10, 2007 | 05:51 PM
francis's Avatar
i have a code P0483 have noe clue what it is does anyone know what it is and how to fix it
thanks james
Old Nov 10, 2007 | 06:05 PM
own1bigtruck's Avatar
The code is for fan speed, not sure if its overspeed or under speed though. Looks by the manual that the fan clutch might be shorted. It says to check and clean the connector, and then check it for continuity. if it is less than 10 ohms, the clutch is shorted.
Old Nov 10, 2007 | 06:09 PM
francis's Avatar
a while back i had a prob. and 3 wires at the connector under the fan got cut. i fix them and hook the colors back toghter like they should have been. and ever since then i have had that code and my fan drive stay ingauged at all times. does it say what wires to ohm out
thanks james
Old Nov 10, 2007 | 06:20 PM
looks like on the fan clutch side you want to check for more than 10 ohms between the brown/light blue wire, and the dark green and yellow wire. If im reading the schematic right, that will be pins 2 and 3.
Old Nov 10, 2007 | 06:28 PM
francis's Avatar
ok thanks hopefully i can figure it out man that fan drive is loud and gets old hearing.
Old Nov 10, 2007 | 07:01 PM
I didnt realize it until just now, but what I told you was for an 06. You need to fill out your signature so we know what we are dealing with. There is also a website that you can download the service manuals. I think it was www.hemiram.com, but i may be wrong. Thats how I got the info I gave you.
Old Nov 11, 2007 | 10:51 AM
francis's Avatar
i looked at that web site and i found nothing. does anyone konw why my fan is locking up all the time i get in my buddys truck and i never here the fan come on when he turns on. and i still have code P0483 and my wires are back toghter just like they should be
Old Jan 28, 2008 | 10:12 AM
dieselpwr's Avatar
I have same problem with my truck. The local diesel shop said the fan clutch is no good. You can get a new one for around 300 bucks. or you can go to the dealer and pay 400 plus there time to fix it.
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
