I hate personal stupidity
In April I put in an Air Dog 150 and figured I would run the wiring across the radiator "bridge" to the alternator for power. Ran that setup with no issues. On the 14th of July I get 10 miles from the house pulling my fully loaded goose neck and looked down and I have no fuel pressure!! I look under the hood and the wires I routed across the radiator got sucked into the fan and shredded. I was able to get power restored to the pump to get it home. The wife and I switched all our clothes and stuff to another vehicle and left the truck and trailer at the house. I didn't want to chance getting into WV or Kentucky or there abouts and my VP take a dirt nap. So long story longer, I drove probably 4 to 5 miles with no fuel pressure. I know there is no crystal ball, but what would you guys do? Replace the VP or let 'er eat? I am sure its just a matter of time. I currently have no codes except a 1693 and haven't gotten that read yet. I just got back last night. Not to happy to say the least. One little 5 cent zip tie could have prevented the issue. I had one on each side of the radiator, just not the middle. Experience 1 me 0! Sorry for my rant.
Any advice, insight is appreciated, I do have the power on the battery now.
swordfish
swordfish
Several years ago a customer brought in their fleet of five 2001 Rams for me to look over. None of them had any fuel pressure, and they may have been that way for months or years. I replaced all the lift pumps and none of the trucks ever had a VP failure that I am aware of. I know that low fuel pressure doesn't do the VP any good, but sometimes I think it gets overblown somewhat.
hey were human and male. things happen. get your fuel pressure system in check with the pump. pull your code any friends have a smarty to pull the code. and run it. unless you rely on the truck daily if it went out its going to go out even at times of a new one in it. I would drive it.
So a little extra lubricity in the fuel on a pump that just may have been run a little dry and maybe galled internally you seem to think is a bad idea or have a problem with ??
It for sure is not going to hurt it and some people actually like the quieter running of the 24V motor with it added to the fuel.
Of course watch for any symptoms of a failing vp - codes, dead pedal, ect.
Other than that not much you can do hopefully it goes another 50k or more for you.
swordfish
swordfish
A Fass or airdog etc, those fuel pumps are a better stronger more reliable unit that replaces the factory lift pump. lift pumps that are new are still weak in the fuel pressure readings. some say you dont want to dip below 5-6 psi. I dont want to dip below 10 psi Personally. most fass and airdog units keep you at 16psi to 22psi pending pump size. my fass 150 I have a steady 19-20 psi on cruise. to 16 psi on hard Open throttle. the aftermarket pumps will usually be mounted on the frame rail close to the fuel tank and this will be considered a pusher pump instead of the factory pump mounted close to the firewall being a lift pump. hope that helps
Yes thanks what is the best one to use I was looking at the Air Dog II 165 gph is this too much pump. I want enough but not too much if it is going to cause other problems. What can these stock engine blocks handle before reliability starts to become an issue?
ptgarcia
27
11-18-2006 09:00 PM
Gotlift01
31
02-16-2006 10:26 PM
