Who has trouble with QUAD RP gauge?
Old 08-11-2008, 09:26 AM
sallyman1's Avatar
I have the slim quadzilla rail pressure gauge. first one died after a month. second one worked fine till lately. I dont know if its gauge or not but instead of giving the usual reading of 7-9 psi (stock lift pump), it starts showing 0-2 PSI. Sometimes im driving slow and it says 0. This cant be possible is it? or is the gauge hooped. i find very erratic readings.
Old 08-11-2008, 10:57 AM
goose2w1's Avatar
Sounds like a bad sending unit. Does the RP portion work fine? I have read about alot of folks having issues with the sender. I gave up on mine along time ago
Old 08-11-2008, 02:25 PM
justin allan's Avatar
same thing with my gauge Line preasure is all over from o to 17 while driving slow. but when I get on it it holds a constant 20. I agree it is anoying
Old 08-11-2008, 03:57 PM
82NDSNPR's Avatar
i had the same issue the rp side would read zero i called quad they told me that the little black unit gets hot and when it does it frys and will only read zero so i had to trade mine back in for a new one and waiting to see if i have more problems with it
Old 08-11-2008, 07:49 PM
sallyman1's Avatar
what black unit? my quad gauge is grey. my rail pressure side works good just not my Lift pump pressure side.
Old 08-11-2008, 10:54 PM
mopardamo's Avatar
Hello,
I have the same issue. The RP works fine but the LP begun reading zero and bouncing around about 2 weeks ago.
Damon
Old 08-11-2008, 11:02 PM
rip 112's Avatar
Mine died after a month. I am not very happy.
Old 08-12-2008, 01:04 AM
WUnderwood's Avatar
seems like I read that a lot of them go bad....
Old 08-12-2008, 03:12 AM
OutOfSight's Avatar
Mine never even worked (FP part), even after trying several of the things their tech guys told me to, they said I could send it back for another one. I bought a real FP guage instead.
Old 08-12-2008, 05:05 AM
AlCorr's Avatar
I'm having the same problem with my Quadzilla Commander fuel pressure gauge. Very erratic readings, keeps jumping all over the place. I started calling Quadzilla in February for a new one. Every time I call they are working on it call back in two weeks, call back next month. I have only one thing to say: "Excellent Customer Support".
Old 08-12-2008, 03:53 PM
mpracehemi's Avatar
So the one I just bought from a member off the classified is junk?? I shouldn't even bother installing it??
Old 08-12-2008, 03:55 PM
rip 112's Avatar
Not necessarily. Alot of ppl haven't had problems. But the chance is always there.
Old 08-13-2008, 05:07 AM
AlCorr's Avatar
Would you like to buy mine?
Old 10-17-2008, 08:50 AM
sallyman1's Avatar
is there a substitute # we can get from napa to replace the quad 1? the LP sending unit canister that is?
Old 10-17-2008, 09:40 AM
It looks like a oil preasure sending unit off of a late 70's gas motor. I have an idenical on on my 79 ford 429 motor for the oil preasure. THat may work??
Quick Reply: Who has trouble with QUAD RP gauge?
