Who has installed arp head stud kit on 12 vavle
Old 09-01-2011, 08:31 PM
SKATERHAULER's Avatar
Just spent a whopping 425.00 for set of arp head studs ( more than i think i paid for my 472 hemi ) anyway who here has installed a set. Cant believe i have to mill .200 off the rocker ped. Seems like a thicker valve cover gaskit would be the ticket
Old 09-01-2011, 08:57 PM
Tate's Avatar
You can grind the webbing out of the valve covers to clear the nut. But the stud won't have as much engagement in the block as designed that way. Just get the rocker pedestals milled. Should be quick and cheap for a shop to do.
Old 09-01-2011, 09:07 PM
Thanks , I have a mill in my shop just cant beleive ARP makes you do this . It just seems like a thicker gasket would do the trick . Anyone make taller valve covers ?
Old 09-01-2011, 09:42 PM
Lil Dog's Avatar
Not that don't cost you $100 each. Machining can't be that bad.
Old 09-02-2011, 02:22 AM
13FOX's Avatar
A buddy made these and it's expensive but they look nice!
Attached Thumbnails Who has installed arp head stud kit on 12 vavle-100_8347.jpg   Who has installed arp head stud kit on 12 vavle-100_8348.jpg
Old 09-02-2011, 07:59 AM
After comparing orig V-ped bolt length to the new stud from ARP , wouldnt have made sense for ARP to just make a slightly shorter stud to avoid any machining? I'm thinking about rather than milling my Valve -ped is simply knocking an 1/8 off off broached end of stud . Has anyone done this and if I need to remove stud simply double nut it .
Old 09-02-2011, 10:57 PM
Tate's Avatar
Its not the stud that causes the issue (if installed properly). The nut and washer height will interfere with valve cover. IIRC, the stud is **** near flush with the nut on mine.
Megaramasaur
20
03-23-2007 06:51 AM
BigBully
12-17-2006 02:19 PM
dodgediesel
21
08-13-2006 10:20 PM
Dshiftff
0
07-29-2006 09:55 PM
Tiger Rag
33
04-04-2006 08:37 AM
Quick Reply: Who has installed arp head stud kit on 12 vavle
