Has Anyone Stacked a Diablo Power Puck with a smarty???
Old 07-28-2010, 01:56 PM
blowinsmoke1's Avatar
I had bout a powerpuck when i got the truck and jsut recently i purchased a smarty i tried running the smarty on level 6 with the powerpuck hooked up...when i hit the pedel there was a few seconds before it kicked in and took off..and when it did it was really ruff..so i took the puck off and run the smarty on level 7...also i know this is off topic but is it possible to use 3rd gen cab lights on a 2nd gen...
Thanks Preston
Old 07-31-2010, 01:00 PM
heavy1's Avatar
not real sure i was running a edge race evo and the puck on my duramax and with both turned all the way up i could only boost about 25 and with just the edge i could boost 36 to 37lbs. i only used the puck to luanch out of the hole so i didnt burn tires as bad then turned it all the way off! Personally i didnt like the set up>
Old 07-31-2010, 03:12 PM
BigGreen's Avatar
Someone real quick explain what stacking is and why would you do it?
Old 09-01-2010, 02:13 PM
costly add.'s Avatar
Stacking is when u take a fueling box (edge comp, quad adr, fms) and run it with a timing box.(smarty, puck, mvp)
mx684
04-07-2008 03:53 PM
supercharged_hp
09-13-2007 03:55 PM
BLUTIC
16
03-13-2004 06:39 PM
Missouri_Mule
06-14-2003 04:01 PM
HAYHAULER
12-09-2002 05:59 PM
Quick Reply: Has Anyone Stacked a Diablo Power Puck with a smarty???
