hard steering?
Old 05-18-2008, 11:22 PM
rebal's Avatar
hard steering?
My 01 steering is hard and on long trips my arm gets cramped up also my brakes are hard too. so im thinking my power steering pump pressure is getting low ?
anyone have this problem? good cure?
I was thinking of an after market pump with higher pressure. sure would like to have it feel like my first gen.
thanks guys Robert
Old 05-19-2008, 09:52 AM
volly818's Avatar
Sounds like your vacuum pump is shot. Check that before you go any farther.
Old 05-19-2008, 10:05 AM
XLR8R's Avatar
Surely you've checked the HydroBoost's fluid level - if it's full & not foaming it sounds like the pump.
Old 05-19-2008, 10:33 PM
rebal's Avatar
it is full and i do have power steering but its very tight all the time
any good place to up grade?
Old 05-21-2008, 07:44 AM
Stamey's Avatar
Before you replace the PS pump, have you tried flushing the fluid for new? This may help sigificantly, and is cheaper than a new pump. If you do end up getting a new pump, any reman pump should be fine. It isn't often these pumps fail, and they have plenty of power in stock form.
Chris
Dargo
01-12-2018 07:45 PM
LUKE-MM-PULLER
10-31-2010 09:35 AM
ocsurf16
03-13-2006 09:24 PM
Palmetto_kid
03-26-2004 11:33 AM
yz
07-05-2003 09:10 PM
Quick Reply: hard steering?
