Hard starting when below 30deg. out???
Old 02-23-2008, 02:05 PM
king5335's Avatar
Ok my truck has been really running good and then all of the sudden I went out one morning when it was bout 15 degrees out and she didn't want to start, it just cranked over and nothing, but when I let off so I would not burn up starter, the lift pump started and got pressure to the hrvp44 and then when you get good pressure to the pump it will start easily
But i was worried I had to much anti-gel in it so I put alot of 2cycle oil in it and after a couple days it got warmer out and it didn't do it for awhile but now she doin it again
Now my lift pump setup is a holley blue on frame rail and another holley blue knockoff mounted in stock location, now I usually run bout 20 - 25 psi at idle and no lower than 15 psi at wot.
I was just wondering if the power puck could be causing this or my makeshift fuel system, saving money for a better lp soon.
Old 02-23-2008, 07:30 PM
98.5Hotrod's Avatar
Are you sure your heater grids are working.
Old 02-23-2008, 07:33 PM
Thedieselkid's Avatar
check the trigger wires on the grid heater solenoids. Drivers side inner fender well
Old 02-23-2008, 08:21 PM
king5335's Avatar
ok I will be sure to check that out, would the grid heater keep it from starting till it got fuel pressure to the vp
Grit Dog
05-13-2014 12:39 AM
fourthandgoal
88
12-27-2011 05:39 AM
RED99CTD
04-20-2011 08:08 AM
Billy DFW
12-01-2008 08:04 AM
abc4yew
03-15-2007 11:55 PM
Quick Reply: Hard starting when below 30deg. out???
