Hard starting after setting for a few days
Old 10-03-2011, 05:17 PM
swed's Avatar
Hi All,
I have a 2001 24 valve h.o. . When it sets for a few days I'm having problems starting this truck,it will start,run for a few seconds and then stall,I then have to crank it for about a minute to get it to restart. I there a common problem with these engines,and can anyone give me an idea as to where to start to fix it? Thanks
Ed
Old 10-03-2011, 08:19 PM
Top's Younger Twin
Scotty's Avatar
Check your fuel pressure. You may have a dead lift pump which in turn will take out the VP-44 injector pump.
Old 10-04-2011, 09:09 PM
swed's Avatar
Should the stock lift pump make any kind of noise when you turn the key on? What is the easist way to check fuel pressure with out a gauge?
dieselfamily
03-07-2010 09:32 PM
boaterman
10-15-2008 10:44 AM
salmon
08-08-2008 07:19 PM
TIMMY22
27
07-12-2006 09:23 AM
02growler
04-21-2006 10:47 PM
Quick Reply: Hard starting after setting for a few days
