Hard Start
Old 01-04-2009, 06:05 PM
bling bling's Avatar
Hard Start
I have an 01 truck. If the truck sits for several hours it cranks slow but fires up. if I run it for awhile and it only sits a few minutes it will crank slow and no start. I can let it crank forjust a sec let off the key and my fuel pressure will build up and it will fire up. I have never had this prob until my fuel gelled a couple weeks ago now i cant seem to figure it out. I have cracked the fuel lines, checked the batteries, starter is new. I cant figure out whats going on
Old 01-04-2009, 08:37 PM
Administrator/Jarhead
madhat's Avatar
I have seen a problem with this, the fuel lines coming out the tank crack, making your truck lose it's prime. I'll post the thread up if I can find it.
Welcome to the DTR, BTW.
Old 01-04-2009, 08:42 PM
madhat's Avatar
Here it is...
https://www.dieseltruckresource.com/...d.php?t=223688
HTH
Old 01-05-2009, 06:13 PM
I would think if it was loosing its prime it would be harder to start after it sat several hours and not the other way around. I did read the thread you posted and thanks for the info. I will check the lines this weekend. I'm starting to think I might have just gotten a crappy starter.
Old 01-05-2009, 06:46 PM
madhat's Avatar
Could also be a starter, they will start harder when they are hot.
You can pop that off easy and take it to autozone to get it tested...
jacob_armour
02-18-2009 01:44 PM
jckdann7
08-31-2008 12:13 PM
jriggs_18
01-11-2007 04:43 PM
Erik Dlux
24
12-08-2004 07:26 AM
Quick Reply: Hard Start
