hard to start and loss of power
my 98 cummins has never been hard to start until the other day i went out and got in it and it turned over for about 8 to 10 times and then it crunk up when it finally crunk it ran just fine but when i went up the road it didnt have any power it even went dead at a couple of stop signs and would be hard to crank back but would eventually start its at the shop now and the man said he checked the timing on the injection pump and it was dead on also he took the turbo off and it was fine i changed the fuel filter and also the rubber fuel hose behind the fuel filter also i took the return hose off and it was pumping plenty of fuel back if anyone has any suggestions i would greatly appreciate it
I would check the fuel pressure or just replace the overflow valve before going any further.
Many times "mechanics" will say you need a new (or rebuilt) injection pump and a new one fixes the problem.
Well guess what? A new pump comes with a new overflow valve that could have been the whole $50 problem.
thanks for all the replys about 20 minutes ago my dad called me and he had went by to check on the trucks progress and by coincidence the man had the gauges on the valve and the valve was reading 0 so hopefully this is my problem
RHC
08-12-2019 03:32 PM
Sarajaye
11-21-2014 06:14 PM
2old2w8
09-13-2008 08:26 PM
