Hard to shift
Hard to shift
I got a problem. I have my NV4500 and when I want to shift into second at the stop light, it does not want to go. I have the southbend con O in it with about 30,000 on it. I dont pull, so I was wondering what would make that transmission do that, or is it the clutch. I have a 115,000 on the truck. Let me know thanks
Re:Hard to shift
Same problem here. My 6 spd is hard to shift as well. I have the South Bend con o clutch also. I'm pretty sure it's the clutch because my reverse grinds when shifted into sitting still. Since theres no synchro for reverse to start with I'm guessing it's the clutch not fully disengaging. I'm thinking about replacing the slave cyl to see if that solves it since they are not adjustable... if that doesn't do it I might just have to find a different clutch for my truck.
Re:Hard to shift
[quote author=dodgeman01 link=board=16;threadid=21460;start=0#msg201506 date=1067143643]
I lifted my truck 2" and ever since then it is hard to get into 1st or 2nd. all the other gears are fine even reverse.
DM01
[/quote]
I think its the driver I had no problem with 1st 2nd & reverse @ Carlisle
DM01
[/quote]
Re:Hard to shift
If the clutch is dragging the slightest little bit you will have trouble shifting. Maybe just bleeding the slave would do the trick? Do they have a bleeder?
Re:Hard to shift
No. The dodge clutch isn't bleedable. The units are sold pre-filled from the factory. I'm sure you can find a way... but dodge didn't make it to be bleedable.
Re:Hard to shift
On my old 96 12 valve i had the same problem..first thing dealer did..change oil...no help..got worse..once it got so bad i had to shut the truck off to get it in gear then start the truck..made a nice grinding noise and i was able to make it the rest of the 300 miles home...they then took it serious and dropped the tranny and found the input shaft and bearing were toast...all under warranty...hope yours is covered
itr.#1446
11-09-2008 09:03 PM
MoparRiggan
29
11-09-2008 12:02 AM
CASMOKIN
Competition / Pulls / OffRoad
12-30-2005 01:28 PM
