View Full Version : How hard to install injectors?
How much am I looking at to install a set of new injectors. Any special tools ? How long to install, assuming I dont spend much time under the hood......yea, I'm a rookie. Any do's and don'ts appreciated. Thanks guys.
dodgediesel4x4
03-24-2004, 01:12 AM
Here check out these sites:
http://www.dieseltruckresource.com/dev/showthread.php?s=&threadid=38632&highlight=installing+injectors
http://www.dieseltruckresource.com/dev/showthread.php?s=&threadid=30199&highlight=installing+injectors
This should get you started. Chime in with anymore Q's that you might have.
Keep on keeping on,
Hunter
rfcom
03-24-2004, 12:33 PM
For a long time, I was hesitant to open up a perfectly good running (and expensive) motor. After having done it, I can now say it was relatively easy. If you follow the directions and take your time and think about what you are doing, it will go very smooth. One of the main things to watch for is make sure the connector tubes are pulled out at least 1/2" before removing or installing the injectors. It took me 4 hours but if I had to do it again, I'd estimate around 2 hours.
Jim
Palmetto_kid
03-24-2004, 12:42 PM
rfcom
Please enlighten us on how it would only take 2 hours. Where did you hit a snag? what should we watch out for?
rfcom
03-24-2004, 08:15 PM
I figure it took twice as long as it normally might because I went really slow, hunted for the right socket sizes, double checked the instructions and service manual, had a beer, etc. The pros claim way shorter install times. To make things easier to get at, I removed the grid heater too.
Jim
