How hard to change out front rotors on 03?
Old 03-21-2011, 07:31 PM
rjweiss's Avatar
I have changed out brake pads before but never swapped out the rotors.
How hard is it change out the rotors on an 03 4Wd?
Ron W.
Old 03-21-2011, 08:48 PM
Fat Tom's Avatar
Remove front wheel
Unbolt front brake caliper
Remove front rotor, usually you will need a big hammer and block of wood to knock them loose.
Old 03-21-2011, 10:15 PM
509Diesel's Avatar
madhat did a nice writeup, they are super easy, make sure you have some PB blaster and a BFH.
https://www.dieseltruckresource.com/...ke+replacement
Old 03-21-2011, 10:52 PM
Brian08Q35004x4's Avatar
Location: This Nazi state of California 2nd home Gilbert AZ under God
Use some anti-seize when yo put them back on. It helps them come off easy in the future
Old 03-21-2011, 11:12 PM
Administrator/Jarhead
madhat's Avatar
Crap that's an old post...
I use a rubber mallet on the edge of the rotors, if that does not do it, I take the big sledge and this the edges by the studs. Not straight on, but on the sides/top/bottom.
Old 03-25-2011, 07:15 AM
rjweiss's Avatar
Thanks guys....for some reason I thought I had to pull the hub off (bearings and stuff) to take the discs off..
Looks like I'min for a 3 beer adventure.
Ron W.
Old 03-25-2011, 07:46 AM
Nascarcamper's Avatar
I use a 2 or 3 foot piece of 4x6 as a battering ram, works on tires, rotors and few other items we won't talk about. A little more forgiving than the standard BFH even though I did break a rotor on a Saturn once with this approach.
Old 03-25-2011, 09:05 AM
madhat's Avatar
Yeah, but usually by this point I'm too craphoused to hold a bfh and a piece of 4x4....
Old 03-25-2011, 01:43 PM
SOhappy's Avatar
Piece of cake....if you can knock-er-loose
There may be some retaining star rings on a couple of the studs, if so remove them first (if it has never been apart).
My elbow still has tendonitis from 3 week ago when I replaced an axle u-joint from swinging that 5 lb sledge, ouch! I finally had to resort to wailing on a big slug of aluminum placed down in the cooling fin gap. The block(s) of wood just didn't hold up. Went through an entire 8' length of 2x4 piece-by-piece before I switch to aluminum. Finally popped off.
Old 03-25-2011, 02:14 PM
Not 2x4, 6x6 is best, 4x6 will do, I don't think I would waste my time with 4x4 even. No hammer at all, just use it like the cops do on TV as a battering ram on the rotor surface... I have even thought about putting handles on my hunk, this has always worked for me, but of course YMMV.
Festus
ABDTR #5
02-03-2013 02:34 PM
Puke
08-15-2011 07:32 PM
dznutz24
10-26-2009 08:27 AM
04ctd
08-03-2007 04:19 AM
javamann
11-30-2004 07:09 PM
Quick Reply: How hard to change out front rotors on 03?
