How hard are the Bands
I have a 47RE Auto Tranny with 76,000 miles on it. I want to adjust my bands for the it's first time but not sure how big of a deal it is. I have good CD manual that tells me how to do it but I sure would like to hear from some of yall that have done it. Would it be better for me just to take it in and have a shop do it??
Re:How hard are the Bands
If you understand the process you can do it.
You are simply going to loosen the jam nut/turn the center bolt in till snug(72 inch lbs ) and then turn it out the required number of turns/tighten lock nut. When tightening the locknut make sure the bolt does not turn.
Front band is externally adjusted and the rear is internal. Must drop the pan.
