H1C gaskets
Old 07-07-2007, 06:05 PM
MJDiesel's Avatar
H1C gaskets
Hello everyone, I hope that your summer is going great! Anyway, I am planning on installing a wastegated 12 cm housing and I had a few questions. First, where could I get the needed gaskets at the lowest price. I saw that the High Tech Turbo website listed a kit for about $22 with shipping to my address. Would it be more inexpensive to purchase through a Dodge or Cummins dealer? Also, I assume that the actuator can be operated by being connected to the intake manifold like a boost gauge. Am I correct? Thanks for any help!
Old 07-07-2007, 09:41 PM
edwinsmith's Avatar
Received 1,038 Likes on 763 Posts
For the oil drain gasket, I made my own from paper gasket material. Works fine and cost a keckofa lot less than the dealer. Same material works on the intake flange.
Edwin
Old 07-07-2007, 11:48 PM
dpuckett's Avatar
I have used anaerobic sealant for the oil drain. I reuse the turbo-to-manifold gaskets twice, then replace on the third time. For the turbo elbow, I leave it connected and remove the elbow and turbo as one, disconnecting it at the boot.
The turbo drain gasket is $1 from the dealer; turbo-to-manifold gasket is $5 from the dealer or CaseIH.
Daniel
Old 07-08-2007, 07:23 AM
Yes, that is how mine is installed. I ran steel line under the engine for a cleaner install.
Old 07-08-2007, 08:23 AM
MJDiesel's Avatar
Thanks for the help, guys!
sammy340
09-23-2004 05:13 PM
Rales
08-08-2003 12:59 AM
DeereDiesel
08-07-2003 10:17 PM
Alec
08-05-2003 02:43 PM
Quick Reply: H1C gaskets
