guys with nos
Old 01-11-2008, 12:02 PM
KMKDiesel's Avatar
guys with nos
You guys that have nos do you run off a hobbs switch or the tps controller and if you have tried both which do you like the best I cant decide what I want to do.
Old 01-11-2008, 07:58 PM
KMKDiesel's Avatar
anyone I know someone must run nos here
Old 01-11-2008, 08:52 PM
lmills's Avatar
tps controller is the best and safest way to go on a big set up. You can do it with hobbs switches, but they do not come on as soft. On a small set up, a hobbs switch will be fine.
Old 01-11-2008, 09:15 PM
KMKDiesel's Avatar
k whats the diff between a small and big set up. I will be running a 50 hp jet for now tell head studs then tops 200 hp jet depends on how much it will take.
Old 01-11-2008, 09:34 PM
lmills's Avatar
50 you will be fine with a hobbs. In fact, I do not suggest it, but I know guys that run more without even using a hobbs switch. They just activate it by push button. At 200 HP, I would start to consider a controller, just for the reason that it is not as aggressive on the engine components.
Old 01-12-2008, 08:03 PM
KMKDiesel's Avatar
will the tps controller slowly bring it on or just open it up wide open
Old 01-12-2008, 08:30 PM
lmills's Avatar
most bring it in slowly, depending on which one you use
Old 01-13-2008, 11:24 AM
KMKDiesel's Avatar
its one from the zex kit I got I picked it up cheap and really only plan on using it on the dyno
Old 01-14-2008, 12:44 AM
morkable's Avatar
I run a wide open throttle switch that is just plain on or off for my 50hp shot... then I have a hand held trigger for the .125 shot. I like having a handheld switch for racing,, if something goes wrong, the first thing you do is drop the trigger, which then automatically kills the nitrous.
Kevin
I SPEED
18
08-19-2007 09:32 AM
Saxet Nomad
0
03-09-2005 03:27 PM
scottrod
02-20-2005 10:06 AM
Art
02-20-2003 08:32 PM
Quick Reply: guys with nos
