Guess the Gear ratio
Old 08-05-2011, 07:23 PM
bobva's Avatar
Found a Dana 70 out of a 91 cummins 2wheel drive 5 speed truck.
The truck is gone owner says no tag on cover.
That leaves me to counting the teeth. I need #s please.
I"d count the teeth on my truck but the rearend is still good I dont what to open it yet.
Or are there any other marking to look for?
Thank You
Old 08-05-2011, 07:40 PM
maxwellp's Avatar
http://www.spicerparts.com/identify.asp
This will tell what it is if your have the tag numbers.
For the no tag one, count the teeth and devide it out. 58/17=3.41
Old 08-05-2011, 08:11 PM
bobva's Avatar
I guess I better rephrase my wording.
What is the tooth count on a 3.54 Axel.
Ring =
pinion =
Thank you
Old 08-05-2011, 08:28 PM
maxwellp's Avatar
Talking
46/13 3.54 Dana 70 Axle
Old 08-05-2011, 08:42 PM
bobva's Avatar
Thanks Max
I also just found this http://www.precisiongear.com/dana70.htm
Again thank you
Old 08-06-2011, 11:58 PM
joeytechman's Avatar
The ratio was stamped on the ring gear in mine
Old 08-07-2011, 12:40 AM
totalloser's Avatar
Or set one drum on something to prevent it turning, turn the other over two full turns, mark and count the number of turns the pinion yoke turns is your ratio.
IE: Two turns of drum= just less than 4 pinion turns=3.90 just more=4.10 etc.
design
32
06-23-2003 10:07 PM
Garz
02-03-2003 09:08 AM
Cutthroat
01-08-2003 09:37 AM
accordionjohn
10-07-2002 12:54 PM
Quick Reply: Guess the Gear ratio
