guages and mounts arrived yest.!!
my new Westach Fuel Pressure guage, and Westach Combo Pyro/Boost guage came in yesterday, as did my full A-Pillar dual cup mount. i also got the HP hose & 4/1 banjo kit. all from Geno's.
before I install (im sure everything has directions to it) I was wondering if any of you guys had some suggestions, or comments that might help me.
thanks a million.
thanks a million.
Re:guages and mounts arrived yest.!!
I would suggest using the full pillar as a replacement rather than a cover. It takes a bit of work but it is well worth it.
I think you can tie into fuse #5 (?) for lights for your gauges that will dim with your dash lights.
-Jason
-Jason
I was told from someone at Geno’s to mount the sending unit for the fuel pressure gauge on the fender well and not on the vp44 because the vibrations would shorten the life of the sending unit. He also mentioned to use a rubber braded hose to the sending unit.
Here is something to read that might help. They are for different gauges but there is some useful information here.
http://i.b5z.net/i/u/265866/i/Dodge_gauge.pdf
http://www.westerndiesel.com/pdf/Gau...0Instr.WEB.pdf
I just installed mine a few weeks ago. The information they provide is worth the hassle of the installation.
Good luck
Good luck
rodsram
09-07-2007 08:54 PM
moss2904
19
02-23-2003 06:16 PM
JayDee
11-01-2002 10:48 AM
