Guage Wiring Help Needed
Old 03-27-2004, 10:01 PM
Rabbit's Avatar
Ok i have my Westach fuel pressure sender installed and plummed in. Now its time to wire up the guage. I mounted the guage just under the ash tray. For the 12v power for the guage i plan on tapping into the wire for the Cigarette Lighter. Should i put a fuse in-line between the Cig lighter and the guage? Seems like a 20 amp fuse is way too big for protection if something shorts out. When i hook up the light for the guage can i use the Cig Lighter power too? I dont care that the light wont dim i just want it on. Oh and 1 more thing i can use the same ground as the guage (the one that goes back to the sender then ground) for the light right?
After i get this wired up and working I hope my next post will NOT be asking for tips on replacing a LP
Old 03-28-2004, 08:11 AM
Administrator / Scooter Bum
Shovelhead's Avatar
Your wiring plan sounds ok to me, if it's only for one gauge.
I used a Painless Wiring module to add 7 more fused circuits to handle accessories.
See if there's a light for the ash tray and use that wiring for the illumination, that will put it on the dimmer circuit.
Old 03-28-2004, 08:28 AM
firestorm's Avatar
You could do it that way. I ran a couple of wires up my A-piller, Hot-Switched hot-lights. All of my tapping is done right in the piller.
Old 03-28-2004, 09:07 AM
Rabbit's Avatar
I just wanted to make sure before i did this. My ash tray does not appear to have a light. Maybe its just burnt out i will check. The wiring kit is what i will use when and if i install more stuff. It seems the best way to get power. As for the A piller. I decided not to use a piller pod because i do not like the look of them. I mounted the guage low so it is almost unnoticeable. I like the stock look in the cab. Thanks
justagoodolboy
12-22-2008 11:26 AM
Equalizer 2
03-10-2008 10:26 PM
Highrlr
02-24-2008 11:30 AM
Evildiesel
07-02-2006 06:39 PM
Hummin Cummins
03-24-2003 07:41 AM
Quick Reply: Guage Wiring Help Needed
