Guage cluster problems
Old 12-12-2006, 07:32 PM
DieselMarine's Avatar
I have a working volt meter guage, the oil presure works most of the time, and the fuel guage has a mind of it's own which I am sure is probably a bad ground at the sending unit. The rest of my guages are completely dead as is most of the bulbs. Is there anybody that sells complete instument clusters or possibly rebuilds them for these trucks?
Old 12-12-2006, 09:11 PM
BRUISER's Avatar
YOu can ix all the lights yourself with jut a screw driver.
dash has 5 screws under top side of dash. the dash will slide forward and all you need to do is disconnect the wires on back of dash.
once you have it out you can change all the lights out very easy.. just push and turn all the little black things and you will see they are just standard lights that even autozone or advance will have.. I just did all 12 on my dash and man what a difference.
while you are in tere you can also check all the connections and see if they are loose or not connected..
worth a shot before spending a bunch of money
Old 12-12-2006, 10:09 PM
2stroke's Avatar
oil pressure gauge can be fixed with a sending unit.
CaledoniaOutlaw
01-16-2008 07:27 PM
rstone
01-23-2007 06:57 AM
Ridiculous
12-21-2006 11:02 PM
robox
03-28-2006 04:06 PM
SilverRam01
15
07-18-2005 05:38 PM
Quick Reply: Guage cluster problems
