Gt3076r
Old 04-01-2009, 06:37 PM
MDLP412's Avatar
Gt3076r
http://www.turbobygarrett.com/turbob...ison_sheet.htm what are your thoughts for a quick spooling upgrade from the hx-35? i was thinking the 3076R would best suit me for a qucik spool towing turbo over a k31 in a twin setup?
Old 04-02-2009, 08:48 AM
The Guru
Mike Holmen's Avatar
I would use a slightly bigger secondary turbo than the GT3076. I plan on building a set using my GT3588R over a S366. You gonna to need to use a big external wastegate to get the exhaust to bypass that smallish secondary top turbo. If you can go with the largest turbine housing you can get, it will help with the egt's is you plan on towing.
