Grinding Feel in Gas Pedal
Old 09-16-2005, 10:43 PM
dogeman53's Avatar
Question Grinding Feel in Gas Pedal
Hello,
I have a grinding feel in my gas pedal when the engine warms up. It only occurs shifting from first to second in my 48re transmission. Anyone else experienced this?
Old 09-16-2005, 11:16 PM
Stingerpup's Avatar
No, I haven't experienced this, but it is interesting.
Since there is no direction connection for the accelerator pedal, and the system is fly-by-wire, I wonder what the 'grinding' is coming from??
Old 09-17-2005, 10:41 AM
Vulcan's Avatar
That sound is the money being sucked out of your wallet every time you hit the go pedal.
Old 09-17-2005, 11:51 AM
Hounddog's Avatar
What year is your truck? Maybe its a 6 speed thing BUT cruise etc on auto/6 speed(can't rember which)is cable and a pivot etc.under d/side battery.It moves with gas pedal.In fact a TSB about a rubbing problem if I'm not mistaken! Look at TSB'S.FILL OUT YOU SIG.With year/model/equipment etc.
Old 09-19-2005, 03:48 PM
bigblock2stroke's Avatar
Originally Posted by dogeman53
Hello,
If you really have an 04.5MY, the TPS is still mounted on the engine like the 03's. It wasn't until 2005MY that they went to the TPS located on the pedal for the autos, because they couldn't figure out how to activate the TV cable on the transmission.
Either way, they are all "drive by wire" even if its mounted on the engine. You probably have a corroded TPS cable or a corroded TV Cable (trans kickdown).
Old 09-20-2005, 12:15 AM
dogeman53's Avatar
This may be a dumb question, but what is a TPS.
Thanks,
DM
Old 09-20-2005, 03:12 AM
Ramtough's Avatar
Throttle Position Sensor
Old 09-20-2005, 03:27 AM
TexasCTD's Avatar
Hello,
I have noticed that on mine too, but really didn't pay it much attention. I just thought it was part of the "personality" of my truck. Mine is also an 04.5 with the 48re.
Are you going to take it to the dealer for warranty?
Old 09-23-2005, 10:32 PM
dogeman53's Avatar
I had them check it when I did the window binding fix. They could not replicate. I will take it in on my next change and make sure the engine is warm and it is occurring.
DM
Old 09-23-2005, 10:35 PM
dogeman53's Avatar
Thanks,
DM
Old 09-23-2005, 10:37 PM
drew03's Avatar
Hello,
my truck does'nt have a "gas pedal". sorry i could not resist.
Old 09-23-2005, 10:45 PM
dogeman53's Avatar
You are so right. If it had a gas pedal there would be severe engine damage!
Old 09-24-2005, 07:18 AM
eldorado's Avatar
I have been noticing the same exact thing. Only while the trani shifts from first to second. A grindind type vibration that transfers up through the fuel pedal.
Old 09-25-2005, 10:16 PM
longbed's Avatar
Have an 03 auto i get feedback in gas pedal on highway after i use the cruise control and turn it off. Is that what TSB is about?
Big Inches
09-12-2010 06:31 PM
600 Megawatts
03-26-2008 07:09 PM
nelrod
01-20-2007 05:52 PM
cLAYH
02-06-2004 10:59 AM
mymaur
06-20-2003 01:14 AM
Quick Reply: Grinding Feel in Gas Pedal
