Grid heater solenoid part number
Old 05-24-2011, 02:04 PM
I pet my truck from time to time....
SILVER GUS's Avatar
Not even my dealer parts dept. can find it. How do they stay in business? Mounts by the passenger side battery tray and controls the grids. I cant find anything online with a part number. I've look under grid heater relay/solenoid. Thanks
Old 05-24-2011, 08:58 PM
gcssr's Avatar
can you pull the relay out , look for p/n it looks to be a standard relay . there is a fuse link, in the wire, check for output. you maybe able to swap the relay, with another unit, out of the fuse box.
Old 05-24-2011, 10:35 PM
torquefan's Avatar
I remember the one for the 2nd gen trucks being 56026842. Not sure if the part was different on the 3rd gens or not. I actually had it printed up under the lid of my toolbox because it was always such a PITA for the partsman to find.
Old 05-25-2011, 08:52 AM
carl48's Avatar
that relay does not fail very often, there is a fuse link between the battery and the relay. disconnect the control wire from the ecm and jumper from the battery to the relay control post you should hear the relay snap. next see if you have 12 volts on each terminal on top. if none on either the link is open if on one the relay is bad
Old 05-25-2011, 08:57 AM
carl48's Avatar
one more thing, you do not need the grid heaters. most of us remove them. the truck will start at 20* below zero with out them. they are a emission item
http://i1141.photobucket.com/albums/...rljr48/212.jpg
Old 05-25-2011, 09:34 PM
SILVER GUS's Avatar
I will check the relay. I was told the solenoid was sticking open causing the drain and then overcharging of the passenger side battery (smoked one and melted the terminal). It's disconnected now and is not draining the battery anymore but is causing the engine light to come on and throwing a code saying "no voltage drop seen at the grid heaters." Thanks for the feedback.
Old 05-27-2011, 07:50 AM
DodgeChallenger's Avatar
Use a continuous duty rated camper solenoid like they used on Camper Specials way back. they have lots of amperage capacity to do this job and they are only about $20-$30 and they never wear out. Also, from time to time, I run some WD40 spray on items like this under the hood then wipe it with a cloth. Moisture still migrates everywhere and plays havoc with electrical parts over time. I also lightly spray all the wiring connection plugs before washing under the hood -same reason.
Old 05-27-2011, 06:27 PM
carl48's Avatar
if you do not wait to start the code will never throw. it works funny, the wait to start light will always come on to train you to wait to start. above 55* the heaters are never cycled. once it is cooler than 55* the ecm looks for a drop in voltage during the wait to start time. if you start the truck as soon as you turn the key on the code will never throw. none of the industrial 5.9's have the heater and the no heater cummins piece is 3922484 i think it is about $22. here is a pix of a heater being removed from a stock one and a stock one next to it
Old 05-29-2011, 11:28 AM
SILVER GUS's Avatar
Here it is. Part number on the side is 56029173AA. I can't find it on any Dodge or Cummins parts online.
Old 05-29-2011, 06:41 PM
johnh's Avatar
the biggest problem is the connectors to the relay, they are not very positive.... i found on mine , if i crimped them a little it tightened them right up and no more codes
Crossy's son
06-02-2008 08:19 PM
CTD2001
10-10-2007 11:58 AM
vtailflyer
06-01-2007 08:44 AM
tgleason
12-07-2004 05:40 PM
Quick Reply: Grid heater solenoid part number
