gregmc truck warm knock
Old 12-18-2004, 08:38 PM
TroyH's Avatar
wondering if you ever got your truck to stop knocking after warm up i have the same problem need to know what you did thanks troy
Old 12-19-2004, 11:04 AM
GregMc's Avatar
I spent a lot of time reading these forums trying to clear up this knocking problem, the dealer hadn't been much help. Fuel treatment seems to be improving the problem. First I tried Diesel Kleen and it didn't do much to reduce the knocking. Then I tried Howes Mean Cleaner, it helped but I could still hear the knock. Next was Red Line Diesel Catalyst and it has proved to work the best for me. You can buy Red Line at Auto Zone and I would suggest you try it, it has worked for me. Run about 3 clean up doses (one bottle for 20 gallons)to clean the injectors.
My truck also sounds different depending on which fuel I buy. I had been using WalMart, Shell, and various truck stop fuels and the truck sounded like crap. I started buying fuels at different stations trying to find out if that would make a difference. My truck runs noticable better, smoother and quieter when I run Citgo Prem. Diesel. Citgo is the only location in my area I have found fuel that is labeled as premium....I don't know what is different about this formulation but it definately helped my truck. I ran Citgo Prem for a couple of tanks then switched back to Shell, then back to Citgo to make sure my suspicions about fuel quality were correct.
I will use fuel treatment in every tank and Citgo fuel from this point forward. Most of my trips are 15 miles less so I will probably do run a clean up dose every few tanks with a maintenance dose of fuel treatment in the others. I have also seen an increase in fuel mileage with the Red Line and Citgo. My overhead is usually within .5 of hand calculations. A trip from Memphis to Little Rock and back last week showed over 22 mpg with the cruise set on 73 mph. The best previous hand calculation was about 20.5 mpg.
Zee
03-23-2010 09:54 PM
HappyGA
15
10-16-2006 08:21 AM
Hoss
30
10-03-2006 02:57 PM
sinwagon2500
16
01-10-2004 01:34 PM
Quick Reply: gregmc truck warm knock
