Governor Springs Again..!
Old 07-04-2007, 02:41 PM
12VRoush's Avatar
Exclamation Governor Springs Again..!
I know again the same thing GSK! Sorry... but i have had enough of this shifting in and out and i am finally going to reset my springs! I need to know how many "clicks" or turns on the retaining nut is considered stock or from factory. PLS i cant get a hold of a calipers, and i am not spending 40 dollars at advanced auto or autozone or any other parts place. PLS if anyone can help me, let me know! thanks
Old 07-04-2007, 02:48 PM
TxDiesel007's Avatar
Best that I can do for you
is get you in the ballpark from other things i have read.. About 6 3/4 turns will get you close. Not sure how many clicks that is. If you cant borrow the calipers, then the best thing for you to do is back off two clicks at a time and keep readjustin till your happy with it..
GSK is all trial and error... especially if you are without calipers....
Rick
Old 07-04-2007, 03:23 PM
12VRoush's Avatar
Thank you i think i will try and do that.... still if anyone can really help out some more thank you.
Old 07-04-2007, 04:19 PM
Sidewinder's Avatar
All you need to do is put the nuts back on to the same depth as they were stock (as a starting point). You don't have to measure them to get a number just use anything you can think of to mark the distance BEFORE you remove them. I think you could even use use a popsicle stick or a piece of paper and a pen to mark the depth. Then when you reinstall the nuts just set them to the same mark. Not very high tech but for the springs it should get you close enough. From there you might then have to adjust them a click or two (or three) to get everything working correctly. This will happen even if you do use calipers. After doing the springs twice I don't think you need the accuracy of calipers (it is better if you have them) but just get them close to the original depth and the same on both springs.
Thats my opinion anyway, other may disagree! Go ahead!
Old 07-05-2007, 05:39 AM
schoust's Avatar
Read this thread it should explain all that you are looking for,they guy that wrote this is very knowledgable on 12 valve's.........http://competitiondiesel.com/forums/...ead.php?t=9688
Old 07-05-2007, 11:23 AM
12VRoush's Avatar
I understand all that but i tried counting the clicks or turns when i first removed them from stock. Now i have the 4k and i didnt get the right amount of turns i guess cause its still doing that and i have readjusted 3 times ? so fgured calipers will be my best bet.
Old 07-05-2007, 11:47 AM
12VRoush's Avatar
also what is everyone using to tighten the nut down i have been using two flat head screw drivers and it gets hard when it tightens up i cant seem to get anymore clicks after 5 or 6. is there a special tool everyones been using or what?
Old 07-05-2007, 12:57 PM
I have a 3/8 screwdriver
works well for me, if it dont work still, grind a notch in the center of it about the width of the stud and ull be golden...
Rick
Leadfoot
11-28-2005 04:26 PM
crossy
05-22-2005 10:33 AM
Getrealgetlifte
03-05-2005 05:38 PM
mr T
17
01-06-2005 11:29 PM
Monty
02-16-2003 03:52 PM
Quick Reply: Governor Springs Again..!
