Got my holley blue should install it with a return line?
I can run it with a return or i can run it as a standard regulator. If i should run it with a return where should i tap in for a return line?
Thanks,
Brendan
Thanks,
Brendan
Yes I have the stock wires hooked up to mine just make sure you turn on the ignition to find out which wire is the power wire. It works better that way so when you turn the key on it turns on the pump for a second then shuts off after pressure is built up. If you hook it up somewhere else it will continually run while the key is in the on position before you start it.
Did ya'll know that the ECM provides power to the lift pump? How many amps with the Holley Blue draw over the stock lift pump?
I would advice using a relay.
ctd4stan
05-18-2009 02:56 PM
AlCorr
114
02-11-2009 02:32 AM
Night Rider
04-28-2008 10:11 PM
Texaschevelle
26
11-16-2007 08:08 PM
