Got a Leak on my Injector Pump 12 valve
Got a leak on the back side of my pump between where the output lines come out of pump. Understand this block is where you can turn up your pump, it look like it is leaking from the top, it has four screws holding this on the back. Question if I take off the back is there any springs, check *****, etc to fall out, looks like I could put a new gasket between and fix it... it runs great just starting to leak just a little drop when it's running?
Dale M
03-05-2011 03:40 PM
TJ0993
11-08-2007 10:27 AM
bhoff1175
06-07-2006 10:19 PM
