Got guages, got questions.
Old 01-18-2008, 08:21 PM
kc8ksg's Avatar
Okay, got a few questions, I just got my guages, pyro, boost, tranny, and fuel psi. I know how/where to hook up the pyro and boost, what about the tranny and fuel pressure? I have heard of people putting the tranny temp in the line that goes to the cooler and I guess maybe the fuel pressure inline somewhere between the LP and IP? Just figured I'd ask first seems like when I think I know how to do something already, I see somebody on here do it a way that is alot easier and think, I shoulda asked!
Chris
Old 01-18-2008, 08:52 PM
rockwithjason's Avatar
for the fuel pressure you can use a tapped banjo bolt from geno's. this is the cleanest way i know of to do it and it's about $10. the tranny temp can be done using a mopar hose part #CH05011244AA. it has a boss for the sender in the hose. you could also cut and tee the hose if you like.
Old 01-18-2008, 09:47 PM
psd tuner's Avatar
there is a little bolt on the front of the trans on the passenger side. i think they call it a servo test port or something like that. i took the bolt out and screwed in my trans temp probe there. i usually run 140* in summer in normal driving and 180* when drag racing, but right now its so cold i usually run a 100*.
Old 01-19-2008, 02:14 PM
kc8ksg's Avatar
Thanks for the tips, they should help make things go smoother!
Chris
Old 01-19-2008, 05:23 PM
MAX340's Avatar
Thats not an accurate trans temp. Most ccurate trans temp will be had in the "to cooler" line.
Old 01-19-2008, 06:50 PM
danalex's Avatar
Chris,
Re the fuel psi connection, I noticed an item on geno's garage you might be interested in.... I've got a post just started on "performance accessories" cuz I didn't know where ask the question... Anyway, the item is a replacement for your fuel fitler cap that has a fitting built onto it--geno's claims it allows easy connection of a psi monitor. I'm considering this, but waiting for addition feedback/post responses. Its a bit pricey, however,...$59 ...my 2cents Here's a link to genos item: http://www.genosgarage.com/prodinfo.asp?number=LT_FFCPP
Old 01-20-2008, 11:23 PM
psd tuner's Avatar
thanks for the info i have been woundering about the placement of my trans temp probe if this is a accurate location or not. why isnt this a accurate location to measure the temp.?
Old 01-21-2008, 12:48 AM
ib516's Avatar
Put your trans temp sender in the cooler line that goes from the tranny to the first heat exchanger. You can do this by cutting the line and installing a tap with one of THESE, or you can buy one of THESE.
Why do you want to read the temp at this location?
THIS WILL TELL YOU - READ IT!
bradmizer
11-11-2008 02:32 PM
bpdp379
02-26-2007 05:45 PM
IBenDCars
02-21-2006 02:17 PM
apache
11-20-2005 02:43 PM
dgm
06-24-2005 12:30 AM
Quick Reply: Got guages, got questions.
