gooseneck on a short bed?
Old 02-13-2010, 12:50 PM
royta's Avatar
What are my options to eliminate possiblities of hitting the rear corners of the cab if I buy a 2nd gen short bed and install a gooseneck ball? How do the extenders that you can buy? Any negatives?
I'm selling my '97 today so I'm in the search for a new truck again.
Old 02-13-2010, 01:04 PM
RAMRODD's Avatar
I use to own a 2000 short bed Dodge and I had no problem pulling a gooseneck with it.
I also have a 05 Ford F-350 short bed and have no problems pulling a gooseneck.
As long as your trailer has a V nose you shouldn't have a problem. If you have a big square nose trailer I wouldn't do it.
Old 02-13-2010, 03:20 PM
rebal's Avatar
yup ^^^
Old 02-13-2010, 03:22 PM
royta's Avatar
OK, what about 5th wheel trailers using the gooseneck to 5th wheel adapter?
Old 02-13-2010, 03:28 PM
OldDodgeOwner's Avatar
It depends on how the 5th wheel is setup. My old 5th wheel I pulled with a shortbed with no problems, but it had the pin extending out in front. If the pin is underneath the neck, I imagine it would be a problem. With the ball moved back, you might still have clearance though.
Old 02-13-2010, 03:37 PM
billie's Avatar
A friend of mine had the pin on his GN extended 10" by a certified shop. Don't know the cost but it wasn't a lot >$1000.
Old 02-13-2010, 04:26 PM
RAMRODD's Avatar
Here is a picture of my old 2000
I see short bed trucks pulling 5ers all the time so I wouldn't think it would be a big problem. Probably best to talk to your RV dealer. You might also want to look into B&W hitches you can get a 5th wheel and a gooseneck all in one hitch. Looks like a slick setup.
Attached Thumbnails gooseneck on a short bed?-163_0402_rr_21z-2000_dodge_ram_2500_4x4-front_right_view.jpg
royta
02-14-2010 05:08 PM
HolyRoller
10-22-2007 10:45 AM
WVdodgeman
05-08-2006 12:07 PM
mcgyver01
07-04-2003 04:15 PM
jhodge
04-16-2003 10:31 AM
Quick Reply: gooseneck on a short bed?
