gooseneck questions
Old 03-14-2010, 11:17 AM
93-331-29psi's Avatar
gooseneck questions
I am considering a move and I want I am looking at buying a trailer to move all my toys at once, but I want to be safe about doing it. My toys include 2 Fox era mustangs about 2800-3000# each, and 2 harleys 750# and 950#. I measured the cars at 15 foot long and the bikes are 8 foot long. I am not too concerned about the weight, but I am not so certain if my truck can safely handle a 40' gooseneck. Thoughts? Comments?
Old 03-14-2010, 11:26 AM
OldDodgeOwner's Avatar
It'd probably handle it just fine. I'd just watch how you load it so you don't get too much pin weight. With a flatbed, I wouldn't worry about it at all.
Old 03-18-2010, 04:13 PM
xyzer's Avatar
Swing real wide on corners.......
Old 03-27-2010, 07:58 AM
Valv's Avatar
It will handle it just fine, difference from yours and a 3500 is just springs, 2 extra tires and the GVW sticker on door. Stay within max rating of truck and trailer combined and you won't have a problem.
Truck label 9900, trailer 21000lbs = 30900lbs max, you might need a CDL
Old 03-27-2010, 08:35 AM
cameroneod's Avatar
I've overloaded my truck many times and never felt the truck couldn't handle it. Take it easy and make sure your brakes are in decent shape. An exhaust brake is a wonderful thing.
Old 03-27-2010, 06:23 PM
cLAYH's Avatar
Driving a 40ft won't be much fun. I pull a 30ft GN and have to be REALLY careful in residential areas. The GN cuts such a shorter turn than the truck I have to watch the neighbors hedges, mailbox and parked cars. Not everyone parks as far back from a corner as they should.....
No way could I get down my street and around the corner with a 40ft. I hope you are going from an acreage to an acreage....
Old 03-27-2010, 09:37 PM
trainermg's Avatar
Your ok
My old 1993 i pulled 26000 pounds with it but on a singel wheel .just don't put to much wieght on the truck! GOOD LUCK
Old 04-28-2010, 07:33 PM
dundun98's Avatar
You'll find where you can't pull in, you can back in.
Old 04-28-2010, 09:22 PM
With age comes the cage
Colo_River_Ram's Avatar
That's why the trailers come with rub rails
Trent2500
08-12-2011 12:17 PM
megafast
03-17-2011 09:00 PM
st.rodder2
04-24-2009 12:57 PM
TexasHardcore
12-10-2008 01:32 AM
Bersaglieri
11-23-2008 11:41 AM
Quick Reply: gooseneck questions
