Good Looking Switches
Old 04-19-2009, 11:32 PM
Krob's Avatar
I am trying to put together all the part i will need to build me work lights to mount off my headach rack. THe one thing i am having trouble doing is finding a switch that i like.
Awhile back i saw a picture of a switch that some one had used here for that. It was grey or black and looked like a little bigger then a good size finger. it might have been a two or three position switch, it went with the fit and finish of the truck. Anyone got any suggestions?
THanks ROb
Old 04-20-2009, 09:19 AM
Checkmate's Avatar
I've got strobes on my truck and had the same dilema. I ended up getting some small oval shaped black rocker switches with leds from Advance Auto. I installed them in the knee bolster under the steering column. I like the fact that they have the leds so I known when they are on.
I've got 4 of them there and they are hardly noticable.
Old 04-20-2009, 11:49 AM
Krob's Avatar
THanks Checkmate, that is probably what i am looking for, do you remeber their numbers or anything else?
THanks
Rob
Old 04-20-2009, 04:42 PM
GUMP's Avatar
I used the same type, mine is red, its really not noticeable, I wanted a factory style switch, but I could not find anything, I was looking for a rear window defogger switch, I had to have mine in, so I quit looking.
Old 04-21-2009, 01:08 AM
BDS
BDS's Avatar
You can find pretty much anything you need here
http://dkc1.digikey.com/us/digihome.html
Brent.
Old 04-21-2009, 04:46 AM
Doj Dewd's Avatar
check out the link in my sig to the reverse lights. the round switch is momentary on - off. the rocker on the knee bolster is on-off-on. the led lights anytime the lights are on - regardless of switch positions. the round push button overrides the rocker switch.
the round switch is from 'the source / circuit city'
the rocker is from NAPA.
sorry, no Pn's - but you can sure spend a while @ NAPA flipping thru the catalogue!
i would also recommend a local electronics hobby shop - they probably will have what you are looking for, and will be in stock.
hth
jason
partisan1911
15
02-02-2012 08:49 AM
CODODGE2500MAN
09-17-2009 08:42 AM
SlowSixSpeed
11-22-2007 04:15 PM
texaspower19
04-12-2006 10:46 PM
fitzer
01-23-2003 06:41 PM
Quick Reply: Good Looking Switches
