how good are 370 injectors?
I have been running 370s from new era that have the corrected spray pattern and I do not have enough fuel, i have my afc let off all the way and ive tried it with the foot out. When go hard with her, the exhaust cleans right up and I have no egt problems. I know i need more fuel, is buying new injectors like some from DDP the answer??
Can try bigger DV's if you want, but I would go with bigger injectors. Those are only 90hp injectors. Get some 140+ hp sticks. What kind of power are you making? Boost?
I have never dynoed it. It makes 70 psi of boost. I didnt know that the 370s were only a 90 hp injector. So you think my limiting factor is my injectors as opposed to my DVs?
My twins clean up 140hp sticks with 181dvs with no problem at all. the 191's will give you more fuel than what I have. I'd go with a 5x .014 or .016 depending on what you use the truck for.
cumminsfreak - my timing is around 16*
BigErksG2 - I just use the truck for a street machine, i dont do any towing and do not care about fuel milage.
its not my daily driver, i just want it to be fun and quick.
thanks for all the input, i learn so much from this site
08-25-2003 10:49 AM
JCamper
05-15-2003 09:30 PM
